Quien dice que no hay megane sport sedán???
Iniciado por checa, 12 de Abril de 2009, 16:06:06
Pues que nos diga como se monta ese ordenador ahí y como va conectado, todo todo y todo. Saludos.
Cita de: jinjinato en 21 de Marzo de 2010, 00:48:00
In english:
Hello J.D.
The user "jinjinato" is interested in knowing everything about how montastes the computer in the car, or whatever here in Spain called CARPC "or" Carputer "
Be interested to on the subject of connections, processing of electricity, screen and all its accessories. Thank you very much
En español:
Hola  J.D.
El usuario "jinjinato" está interesado en saber todo sobre como montastes el ordenador en el coche, o lo que aqui en españa llamamos "CARPC"  o  "CARPUTER"
Interesaria sobre el tema de conexiones, transformacion de la electricidad, pantalla y todos sus accesorios. Muchas gracias
lionheartjf
y si os habeis fijado tambien tiene en el centro del cuadro velocimetro otra pantalla a color en la que sale cosas de un navegador, lo en vi en otras fotos de hace mas tiempo cuando aun no tenia el tema del apoya brazo y demas
Cita de: lionheartjf en 21 de Marzo de 2010, 10:09:04
Si, creo que eso lo trae de serie el coche
j.d
Thank you Raw.
No, that is not a standard option. In the instrument cluster, between the speedo and the revs, is a 2.7" Mio Navigation system. Basically, it's a Mio H610 mounted in there.
Just for your information, the pictures below are very old.
The computer consists of a 1.8Ghz Celeron CPU with 1GB DDRAM, a 260GB HDD and loads of USB devices. The computer is mounted in the glove box. For that I needed to modify the Travla C137 case a little bit so that it would fit in there. Everything is powered by an Opus 150W PSU.
The "cool" thing about mounting it in the glove box, is that the carpc is cooled by the AC at all times. Also in the glove box we can see the IR sensor from the cordless notebook size keyboard.
The screen for the computer is a 7" Hitachi custom mounted on top of the center console. The console is custom made, and it's based on the X3/Z4 OEM navi, custom modified to match the Megane's dashboard and it's a motorized fold in/out type of monitor.
The entire PC is controlled from one single point...everything from mouse movement to volume adjustment is made from the SpaceNavigator located just above the handbrake.
Some of the functions like volume control next/previous song or play list shuffle are also available on the modified steering wheel control, where a Griffin Powermate unit is integrated as well.
There are a lot of USB devices hooked up to the CarPC, like:
1. DVB TV Tuner with the antenna hidden away in the stock tweeter location.
2. FM Tuner
3. GPS BU 303 mouse also hidden in the same location
4. The 2.7" Mio H610 custom navigation located in the clocks is also permanently hook up to the PC through an USB port. It's antenna is also hidden in a stock tweeter location.
5. Griffin Powermate in the steering wheel controls
6. USB joystick for the actual steering wheel controls
7. USB DVD player - mounted just below the factory CD player
8. USB Wifi stick - also hidden in the dashboard
9. USB GSM modem for Internet connection
10.Bluetooth for phone connection and for a mini Bluetooth Keyboard.
Future plans:
11.USB Rear Parking sensors
12.USB Tyre Presure Monitoring Sensors
13.USB Valetine One radar Detector
Of course navigation could've easily been implemented on the carpc, but the fact is the pc is handling so many devices and it can do so many things, I just didn't want the screen to be always showing the navigation.
That's why I decided to have a separate navigation system. Custom mounted inside the clocks it's a 2.7" Touch screen Mio H610 navigation system. You can see in the first pic the factory clocks that come with the Megane. I also changed the background foil with a black one, sprayed with black the inner plastic rings, and added two chrome rings that really give the interior a premium touch.
The key and STOP warning lights have been also relocated in the left/right of the trip computer.
One of the most interesting things the CarPC does is the DSP feature. I have no head unit, so the sound commes out of the PC directly into the 3 amplifiers mounted in the trunk.
So the sound is processed by the PC with the help of the Audiotrack Prodigy 7.1 HiFi Sound card (made by ESI) and a few very smart bits of software.
The sound system is a 4 way active system and it consists of the following:
- tweeters: Helix RS801 Competition custon mounted in the side mirror supports
- midrange: DLS Iridium 3" custom mounted in the front doors (the design is not yet finished)
- midbas:  Helix RS806 Competition
- Subwoofer: Helix E30 in custom case inside the trunk
- amplifier for the mids and tweeters is a Helix DB4
- amplifier for the midbas and subwoofer is a Helix DB5
The soun system is still under heavy construction, so pics will follow soon...also, the entire car will be sound proofed with Dynamat Xtreme.
Now, in english:
Awesome, I was very clear! The truth that once again I must congratulate you for your work. Honestly this is customization and the rest is lies.
I want to thank you for your great help giving us these, and the explanations so detailed that you put. Now I read "jinjinato", yet this is what lead me (ha ha ha)
As for the rest, I am yet to teach me more detailed photos of the blind that you put next to the handbrake lever.
Many greetings and thank you very much for your time and dedication
Ahora en español:
Impresionante, me ha quedado muy claro! La verdad que una vez mas, tengo que darte la enhorabuena por tu trabajo. Sinceramente esto es personalizacion y lo demas es mentira.
Quiero agradecerte tu gran ayuda que nos estas dando, y con las explicaciones tan detalladas que pones. Ahora lo leera "jinjinato", aunque para ello se lo traducire yo (je je je)
En cuanto a lo demas, quedo pendiente de que me enseñes mas fotos detalladas de la persiana que has puesto junto a la palanca de freno de mano.
Un gran saludo y muchas gracias por tu tiempo  y  dedicacion
Ahora traduzco un poco lo que ha dicho en el siguiente post
Cita de: j.d en 21 de Marzo de 2010, 23:35:47
Gracias Raw
Gracias primas.
No es una opción estándar (el tema del navegador) . En el panel de instrumentos, entre el velocímetro y las revoluciones, es una pantalla de 2,7 pulgadas para la navegación. Básicamente, se trata de un Mio H610 montado allí.
Para vuestra informacion, las fotos de aqui abajo son un poco antiguas
El equipo consta de una CPU Celeron 1.8Ghz con 1GB DDRAM, un 260GB HDD y los accesorios/dispositivos USB. El equipo está montado en la guantera. Para que tenía que modificar el caso C137 Travla un poco para que se encajaba allí. Todo lo que es alimentado por una fuente de alimentación 150W Opus
La pantalla del ordenador es una "Hitachi" personalizada de 7", montado en la consola central. La personalizacion esta basada en el X3/Z4 (se supone que del modelo BMW) tactil, personalizada para que coincida con el salpicadero. Es una pantalla motorizada que se abre y se cierra sola
El ordenador controla todo desde un solo punto ... todo, desde el movimiento del ratón para el ajuste del volumen se hace del raton de navegacion, situada justo encima del freno de mano.
Algunas de las funciones como control de volumen siguiente / anterior canción o lista de reproducción aleatoria también están disponibles en la versión modificada del control de volante, donde una interfaz está integrado también.
Hay un montón de dispositivos USB conectados a la CarPC, como:
1. Sintonizador de TV DVB con la antena escondida en la ubicación  del tweeter
2. Sintonizador de FM
3. GPS BU 303 mouse también oculto en el mismo lugar
4. El 2,7 "Mio H610 navegación personalizada situado en los relojes también es permanente conectar al PC mediante un puerto USB. Es la antena también está oculto en el tweeter
5. Interfaz, o controlador en los mandos en el volante
6. Joystick USB para los controles
7. USB Lector de DVD - montado justo debajo del reproductor de CD de fábrica
8. USB Wifi - también se oculta en el salpicadero
9. USB módem GSM para la conexión a Internet
10.Bluetooth para la conexión de teléfono y de un mini teclado Bluetooth.
Planes futuros:
11.USB Sensores de aparcamiento trasero
12.USB Tiro sensores de monitoreo Presure
13.USB detector de radares
La navegación fácilmente podría haber sido ejecutada en la CarPC, pero el hecho es que el PC se encarga de tantos dispositivos y puede hacer tantas cosas, yo no quería la pantalla para mostrar siempre la navegación.
Es por eso que decidí tener un sistema de navegación por separado. Personalizado y montado dentro de los relojes (2,7" táctil Mio H610 navigation). Se puede ver en la foto de la primera fábrica de relojes que vienen con el Megane. También cambió el papel de fondo con un negro, rociarse con anillos de plástico negro del interior , y agregó dos anillos de cromo que realmente dan al interior un toque de primera calidad.
La clave y las luces de advertencia parada también se han reubicado en la izquierda / derecha de la computadora de viaje.
Una de las cosas más interesantes de la CarPC no es la característica de Dispositivo. No tengo ningun reproductor, por lo que el sonido lo lanza directamente el ordenador a los  3 amplificadores montados en el maletero.
Así el sonido es procesado por el PC con la ayuda de la Audiotrack Prodigy 7.1 Tarjeta de sonido HiFi (hecho por ESI) y unos programitas muy inteligente de software.
El sistema de sonido es un sistema activo de 4 vías y consta de los siguientes:
- Tweeters: RS801 custon Helix Competencia montado en el espejo de soportes laterales
- Gama media: DLS Iridium 3 "personalizado montado en las puertas delanteras (el diseño aún no está terminado)
- Midbas: Helix RS806 Competencia
- Subwoofer: E30 Helix
- Amplificador para los medios y tweeters es un DB4 Helix
- Amplificador para el midbas y subwoofer es un DB5 Helix
El sistema de Sonido aún está en construcción lenta, por lo que seguirá pronto fotos ... Además, todo el coche se insonorizadas, con Dynamat Xtreme.
traduccion mas o menos para que lo entendais tooodo
Madrecita... venga los entendidos, donde encuentro todo eso jejejeje Y costará una pasta no??? Impresionante j.d.
Cita de: jinjinato en 22 de Marzo de 2010, 07:34:35
Simplemente la pantalla la tengo avistada por 110 euros!!!
lionheartjf
este tio es una maquina que envidia me da todo joe...
Sirio
es que el muchacho este lleva las intermitencias en los espejos retrovisores, integrado!!
carpin extreme palencia
Cita de: jinjinato en 24 de Marzo de 2010, 00:17:50
Cita de: carpin extreme palencia en 24 de Marzo de 2010, 00:17:19
que por cierto eso lo venden por ebay
Bien, ¿donde??? jejeje.
jorge puso un enlace en este mismo post en la pagina 1 o 2 a beay, no recuerdo exactamente... si la veo te lap ongo aqui
no lo veo en estas 9 paginas, seguire buscando
molina
ufff que coche ya quisiera yo mi sedan asi uff pues no hay que hecharle pasta jaja toda lakeno tengo xd pokito a poko xd saludos
MOLINA
molina
nose porque depues de haver visto este video me alegro de haberme comprao un sedan jaja
MOLINA
Franmalaga
jojojo vaya crack este si que nos pone los dientes largos jajaj que chaval mas inteligente sobre todo con lo de la reproduccion por 4 vias y lo del navegador en los relojes
