[Juego]1.000.000.000
Iniciado por eliminado-83, 08 de Octubre de 2007, 22:32:05
eliminado-83
Os explicare en que consiste, hay que ir bajando (P.E: 3-2-1-0), y el que llegue a 0 se lleva un premio, es igual que el de forocoches, pero para el club, y servira para momentos en el que esta muerto el foro, para divertirse un poco
eliminado-83
999.999.999
999.999.998
999.999.997
999.999.996
999.999.995
999.999.994
999.999.993
999.999.992
999.999.991
999.999.990
j2002
Koleos 2.0 dCi Privilege
alber
999.999.989
999.999.988
999.999.987
999.999.986
999.999.985
999.999.984
999.999.983
999.999.982
999.999.981
999.999.980
cual es el premio? jejeje
crow1987
999.999.979
999.999.978
999.999.977
999.999.976
999.999.975
999.999.974
999.999.973
999.999.972
999.999.971
999.999.970
999.999.969
999.999.968
999.999.967
999.999.966
999.999.965
999.999.964
999.999.963
999.999.962
999.999.961
999.999.960
999.999.959
999.999.958
999.999.957
999.999.956
999.999.955
999.999.954
999.999.953
999.999.952
999.999.951
999.999.950
999.999.949
999.999.948
999.999.947
999.999.946
999.999.945
999.999.944
999.999.943
999.999.942
999.999.941
999.999.940
999.999.939
999.999.938
999.999.937
999.999.936
999.999.935
999.999.934
999.999.933
999.999.932
999.999.931
999.999.930
999.999.929
999.999.928
999.999.927
999.999.926
999.999.925
999.999.924
999.999.923
999.999.922
999.999.921
999.999.920
999.999.919
999.999.918
999.999.917
999.999.916
999.999.915
999.999.914
999.999.913
999.999.912
999.999.911
999.999.910
999.999.909
999.999.908
999.999.907
999.999.906
999.999.905
999.999.904
999.999.903
999.999.902
999.999.901
999.999.900
999.999.899
999.999.898
999.999.897
999.999.896
999.999.895
999.999.894
999.999.893
999.999.892
999.999.891
999.999.890
999.999.889
999.999.888
999.999.887
999.999.886
999.999.885
999.999.884
999.999.883
999.999.882
999.999.881
999.999.880
999.999.879
999.999.878
999.999.877
999.999.876
999.999.875
999.999.874
999.999.873
Si el premio es bueno me tiro un dia 2 horas y lo gano , habra que poner limite
el_txetxu
¡¡¡Esto es una tonteria como un templo!!!, un hombre puede morir contando tanto, para estas cosas dios inventó los ordenadores, sólo hay que saber decirle al ordenador "cuenta cabrón", y él lo hará todo. Os voy a enseñar la barbaridad que supone esta cuenta atrás. Partimos de un pequeño programa en Java, es un programita de primero de programación que lo que hace es simplemente coger el 1000.000.000, restarle 1 mientras que no llegue a valer 0:
public class CuentaAtras {
private static long valor = 1000000000L;
public static void main(String[] args) {
while (valor > 0) {
System.out.println(valor--);
Paso de ejecutarlo en el ordenador del curro, y mucho menos en el mio, así que os voy a pasar algunos cálculos que preveen lo que va a pasar si algún dia se completa la cuenta atrás:
1. Imaginad que un ordenador bastante potente tarda en cada resta de 1 a 1000.000.000 unos 10ns (nano segundos), eso son 10mil millones de nano segundos. Un segundo son un millón de nanosegundos, así que son 10.000 segundos, lo divides entre 60 y tienes el ordenador trabajando durante 166 minutos que son casi ¡¡3 horas!!... Bueno, ahora hacer la cuenta con lo que tardaria un humano, poniendo medio segundo o así....
2. Ahora vamos a calcular lo que ocuparia almacenar esa cuenta atrás en el foro, supongamos que cada carácter que escribimos ocupa un byte (según la codificación, lo más probable es que sean 2). La longitud varia entre los 10 carácteres del 999.999.999 al 1 carácter que ocupa el 1. La cuenta es complicada para la resaca que llevo, así que voy a contar sólo el retorno de carro, el que hace que pase a la siguiente línea cuando pulsas el intro. Son 1000.000.000 retornos de carro, a 1 byte cada uno (repito, seguramente serán 2), teneis que dividirlo tres veces entre 1024 y obtendreis el valor en GigaBytes, ¡¡¡salen 0,9GB!!!, ¡¡¡casi 1GB nada mas que en retornos de carro!!!... ¡¡Pero salvajes!! ¿qué pretendiais? ¿dejar el foro sin espacio?  8-O  8-O  8-O
3. En el hipotetico caso de que haya un premio, que me lo den a mi, si quereis la prueba quemo el fichero con la solución en una tarrina de DVD's y os la envio, siempre que el premio sea algo mas que un par de DVD virgenes, porque para quedarme igual o peor ...
<<(º> RENAULT MEGANE 1.9 dCi 120c.v. - Confort Expression <º)>><
Ritxy1987
999.999.872
999.999.971
999.999.970
el_txetxu
Cita de: Ritxy1987999.999.872
999.999.971
999.999.970
¡¡¡¡Jajajajja, si contais palante y patrás si es verdad que no vais a terminar nunca!!!!  :-A  :-A  :-A  :-A  :-A  :-A  :-A  :-A  :-A
crow1987
dios invento el excel para algo , copias dos y tiras para abajo xDD
ReND
Cita de: el_txetxu¡¡¡Esto es una tonteria como un templo!!!, un hombre puede morir contando tanto, para estas cosas dios inventó los ordenadores, sólo hay que saber decirle al ordenador "cuenta cabrón", y él lo hará todo. Os voy a enseñar la barbaridad que supone esta cuenta atrás. Partimos de un pequeño programa en Java, es un programita de primero de programación que lo que hace es simplemente coger el 1000.000.000, restarle 1 mientras que no llegue a valer 0:
while (valor > 0) {
Me has leido el pensamiento xD pensaba hacer un pekeño script y ponerlo pero al llegar a tu comentario... me has cortado todo el rollo jeje
el_txetxu
Cita de: ReND...
No hay problema, tu haz el script que cuente del 1000.000.000 hasta 500.000.000 y yo del 500.000.000 hasta el 1 y nos repartimos el premio a partes iguales  :-A  :-A  :-A  :-A  :-A
ReND
999.999.971
999.999.970
No obstante pongo mi granito de arena
999.999.971
999.999.972
999.999.973
999.999.974
999.999.975
:-A  :-A  :-A  :-A  :-A
crow1987
podemos poner un numero menos por cada foto que tiene el ban de Rend , es nicreible no termina nunca jeje que paciencia haciendolo
jorecraina
999.999.974
999.999.973
999999....
.3
2
1
0
ganeeeeeeeeeeeeeeeeeeeeeee  :-E  :-E  :-E  :-E  :-E
div style='text-align:center'>
Mecagüen II 1.9 DCI 120 cv. dopados
Azul de otramano, sentajos casi en cueros, lunas pintadas, comprandix, 8 globos, bolsitas pa gomitar y más botones mu raros que es mejor no tocar por si tiene autodestrución.
Ritxy1987
Komo la lio.... xDDDDDDD
No se puede ekivokar uno ehhh
:-E  :-E  :-E  :-E  :-E  :-E  :-E  :-E  :-E  :-E
-1
-2
-3
-4......
:-E  :-E  :-E
peyasgt
spectro
-5
-6
-7
-8
-9
-10
a ver quien tiene huevos de llegar a 1.000.000.000.000
Cita de: peyasgtotro post chorras?
otro? si yo creo q la mayoria de los post de este subforo son chorras!!
zax
Cita de: karoll_
Es cierto, la mayoría son chorradas, pero en este hay que pensar y .... hacer cálculos .... y ..... uf, yo paso. ;-)
WaRlOrD
A esto se le llama Floodear, ¡furros!
Que ganas de petar la base de datos con chorradas...
_^ Zoom - Zoom ^_^
Plataforma:S.H.A.K.T.A.L.E.
